Polyester Fuse repair
Old 02-20-2005, 11:23 PM
elmshoot
Default Polyester Fuse repair
I have a "moderatly" crashed plane with a Glass fuse. When I look at all the glue work inside of the fuse most of the joints have poped loose. I started to sand on the inside of the fuse to put a patch in place and the dust from the fuse has that smell like it has been molded with Polyester resin which I think is why all the joints have poped loose. I seem to remember that the only thing that will stick to Polyester is polyester. If you have any advice on how to go about my repairs chip in here but I think I am stuck with stinky Polyester if I want to do this repair properly.
Sparky
Old 02-21-2005, 12:09 AM
The Ghost
The Ghost's Avatar
Default RE: Polyester Fuse repair
Yes you can use polyester, but you can also use Epoxy, but you have to ruff up the surface a littie bit so it will grab. Epoxy on a smooth surface will pop.
Cheers,
Old 02-21-2005, 02:56 PM
SST
Yes, you can use epoxy on cured polyester, but polyester will not stick to cured epoxy. Go figure...
Old 02-21-2005, 05:08 PM
elmshoot
Cool!!! Thanks for your help I can use epoxy on the polyester. Marital bliss will remain in the house, I had told the wife that i was going to be stinky Whew!!! I always ruff up the surface with some 50 grit for better adhesion.
Sparky
