OMP - Ohio Model Products Support ForumDiscuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Yes, I just ran the ant. out the hatch area through a hole in the bottom of the fuse and then along either the bottom or left side of the fuse. You can still install a short piece of nylon tube from the bottom of the fuse straight up into the rx hatch area pretty easily. Just drill the hole in the bottom balsa fuse capping and sharpen the nylon tube end and hand feed it up. Works really slick.
