''tuned'' pipe
RE: ''tuned'' pipe
The exhaust technology is same as in the real automotive world.
A tuned pipe will depend on the volume it can hold and the length of the pipe. For example, the bigger the inner pipe diameter, the better.
Also a straight and unrestricted pipe works the best.
So, in the Savage, if you can somehow fit a straight pipe directly from the engine exhaust, through the rear shock tower, past the rear bumper with a descent amount of inner piping, that would work great. IMO.
RE: ''tuned'' pipe
ok but you must at least agree a unrestricted exhaust pipe will have better performance than a bent or curved pipe... better exhaust flow in this case.
RE: ''tuned'' pipe
ORIGINAL: bam.bam
Jason
RE: ''tuned'' pipe
ORIGINAL: electrogoneglow
This would not work, how would you preasureize the fuel tank, a straight pipe would not create enoughf back preasure, just my opinion.
However, afix a tube fitting on the exhaust pipe at, perhaps 15 degrees, pointing towards the rear and as close to the engine as possible may fix the issue.
Or maybe not...
VA
RE: ''tuned'' pipe
ORIGINAL: bam.bam
These 2-strokes need the return "pulse" (oversimplified: backpressure) into the exhaust port to help load the cylinder properly. Without this, the engine would have a crappy narrow powerband... Remember, the exhaust port and intake ports seriously overlap. Bigger is NOT better in this case. The word tuned denotes something here...
PA
RE: ''tuned'' pipe
Frost speaks the truth, there's more going on in an exhaust system than one might think. Remember, an engine is nothing more than a air pump. How efficiently it pumps air is determined by many factors, but one of them is the exhaust. The exhaust side is every bit as important as the intake side of the pump/engine. Especially, when your trying to get the most out of your engine. It doesn't matter if its a 2 or 4 stroke, an rc car, plane, heli, boat or the full size vehicles their modeled after. Trying to achieve efficient flow of air/gases through the engine is what helps maximize the design of the particular engine your dealing with. In a "nut shell", the more you can get in, the more power you can make. The exhaust side helps this process by providing an exit for spent gases, but, more importantly, the shape and volume of the exhaust can increase the flow of air/fuel from the intake side into the chamber by scavanging. Essentially, creating a vaccume that gives the air/fuel a head start on the way in. That's why there's an overlap, a point where the intake and exhaust are both open at the same time and the type of pipe is what determines how this overlap will help create power and in what part of the rpm range you can expect it. To better understan this, I highly recomend you read the article that the link below takes you to. If it doesn't, just type it in as written.
www.rcnitro.com/rn/articles/tuned.asp
It explains the exhaust system from an rc point of view. Hope it helps!
