HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Set screw in rear diff case
Old 04-07-2006, 10:42 PM
chefboyrd
Default Set screw in rear diff case
Gang,
What is the purpose of the set screw in the rear differential case? Im sure the front has one too but I have not rebuilt the front yet?
-Thanks
Chef
Old 04-07-2006, 10:45 PM
JayC1968
JayC1968's Avatar
Default RE: Set screw in rear diff case
it is to slide the pin for the shaft in and out of the cup.
Old 04-07-2006, 10:51 PM
JayC1968
JayC1968's Avatar
You will find that when you have to rebuild your diffs that the screw comes out and you slide the pin that holds the shaft that drives the center dogbones out through that hole to remove the shaft itself.
chefboyrd
Jay,
Still a bit unclear...can you explain a bit more..sorry
Old 04-07-2006, 10:54 PM
JayC1968
JayC1968's Avatar
You will find that when you have to rebuild your diffs that that screw comes out and you slide the pin that holds the shaft that drives the center dogbones out through the hole where the screw was to remove the shaft itself.
Old 04-07-2006, 11:15 PM
chefboyrd
my mistake...Im describing the wrong screw. Im talking about the set screw that is inside the diff case on the black plastic cup that houses the bevels gears.
Sorry for the confusion
Chef
Old 04-08-2006, 12:15 AM
TireDr
I know what you are talking about. Its a very small screw in the diff case. I THINK it locks the rear diff. I tightened it down and I could not spin the diff. I am not EXACTLY sure what it's suppose to do. Maybe someone will chime in and let us all know!! I have the LE if that makes a diff. Still new and learning!! [8D]
TireDr
Old 04-08-2006, 12:20 AM
joes75
joes75's Avatar
ORIGINAL: chefboyrd
Chef
What jay said is what it is for, do you have a manual? If not heres the pic of it...
