glow plug wrench
LA
glow plug wrench
whats the best one i went tru 3 of them in a couple of months you know how they suppose to hold the glow plug with out falling they stop doing that!
RE: glow plug wrench
I have an HPI I have had for 5 years and still holds the glow plug fine but I did buy another one that is longer as with the X style engine guard and LCG chassis makes it easer getting the plug in and out. Have not had the Dubro long but is working fine for now.
http://www2.towerhobbies.com/cgi-bin...?&I=LXBDD1&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXD711&P=7
LA
thunder does this glow plug wrench holds the glow plug with out it falling out?
ORIGINAL: savage.27
ORIGINAL: MonteCarloMan
My girlfriend says I'm a nutty driver.
Well..... one of them does...... shhhhhh.
Did not find one that was magnetic but a little lesson in proper terms of what I think he was talking about. Nut Driver
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
[sm=teeth_smile.gif]
LA
cool i can just go to sears and pick it up!!! but if i buy this where am I going to put my glow plugs cause my glow plug wrench is also a glow plug holder!! do they have a separated glow plug holder that i can get!!!
Yes this is one of many.
http://www2.towerhobbies.com/cgi-bin...?&I=LXL712&P=M
All so if you get a NUT DRIVE from sears make sure it is magnetic or you still have the problem of the plug being held.
NC
I don't like that whole storing the glowplugs in the wrench thing. Seems like an easy way to get dirt in your engine if you aren't careful.
MI
I use a nut driver too, but not a magnetic one as I set the plug in and get the threads started with hemostats first. always if you can give a good shot of compressed air before you pull your plug.
Yes I all ways give mine a shot of air before removing to make sure dirt does not get down in the engine. Good reminder for all. I even have a small air compressor I take to the track with me and unless there is a long heat I blow off around my fuel tank cap before refueling.
