Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Which is best tuned pipe fo ZDZ-50NG ??
Old 11-07-2006, 11:18 AM
toreo
Default Which is best tuned pipe fo ZDZ-50NG ??
Old 11-07-2006, 11:57 AM
rmh
rmh's Avatar
Default RE: Which is best tuned pipe fo ZDZ-50NG ??
depends on what rpm band you want it to run in--
I like the AMT and use a long header -
also the KS 50-60 size full length should do the same just make the header long enough to get "pulses" matched to desired rpm.
best power band is over 7000rpm I have set em up with 22x8 Mejzlic to run smoothly for aerobatics in 7750-8400 rpm band.
this picture shows that example
