G-25 Carb Problem
Old 12-07-2006, 03:39 PM
BillPTC
Default G-25 Carb Problem
Attempting to adjust G-26 carb. Even through I have the low end needle turned to only 3/4 turn out I am getting raw fuel bubbling out the carb. Engine 2 years old swinging top flite 18x6 on Super cub. Everything in carb looks clean and assembled correctly.
Is this needle setting? High or low? Carb problem?
Bill PTC
Old 12-07-2006, 04:22 PM
blackbaron
My Feedback: (92)
Default RE: G-25 Carb Problem
Remove the metal plate on the bottom of the carb and clean it. There is a little valve under the diaphram that sits on a rod and sping. If this valve is stuck open than gas will flow out of the carb like what you are experiencing. Clean it really good and re-assemble.
3/4 turns out on low is not correct! Try setting the Low at 1-1/2 turns out and set the H needle at 2 turns out.
If this does not resolve the issue, replace the carb.
Old 12-07-2006, 04:47 PM
captinjohn
Is this a carb on a G25 or a G26 engine, or do both engines have same carbs? What is carb model no? Capt,n
Old 12-07-2006, 05:00 PM
Antique
Antique's Avatar
2 years old, might need a new diaphragm..A diaphragm kit is less than $5.....D10 or D11 WAT is the number.....
