Ofna flywheel wrench
will the ofna fywheel wrench fit associated flywheels? i e-mailed ofna a week ago and still havent gotten a response. here is a link to it
http://www2.towerhobbies.com/cgi-bin...?&I=LXBDV1&P=7
IN
I have seen people try to use the flywheel wrench and end up snaping off a pin so I wouldnt suggest using one. I use a good heavy rag doubled up or a thick welding glove to put over the flywheel and use channelock pliers and have never damaged one yet just dont squeeze to hard or let it slip. I dont tighten the nut real tight when installing the flywheel instead I use blue locktite so the nut isnt too hard to remove, it has worked great this way over the years with no problems. The trick here is not to overtighten the nut making is near impossible to get off.
i put a sock over the flywheel lol. im going to tighten this one up good, and use locktite like always. what really sucks is that the engine runs the loosen way instead of the tightening way, i wish someone would make a clucth nut that tightens conterclockwise.
