Spektrum reciever in fusion
My Feedback: (27)
Considering getting the new spektrum reciever. My question is how to arrange the two recievers perpendicular to each other in such a tight fuse?
RE: Spektrum reciever in fusion
Don't know Earl. You'll probably be the first but I would follow the radio manual as for recommendations. I think all they want you to do is simply orient the antennas in different "planes". For example orient the main rx with the antennae running up and down and maybe the second ant board with its antennae running side to side.
I'd put the main part of the receiver in the center of the fuse, like the manual shows, leaving the antennas pointing front to back. Then use a little patch of velcro to hold the secondary part, down a little into the wing panel. Rotate that part 90 degrees, to make the antennas run span wise.
Otherwise, put the main part inside the wind, with antennas pointing span wise, and cut a little hole in the left wing sheeting, near the fusealge. Run the receiver connector through the hole, and velcro the secondary receiver on the left side of the plane, with antennas running front to back. This is how I have mine on my profiles.
NE
Tail twister that is exactly how I mounted mine on my fusion. I flew my fusion 90 seven times today still absolutely in love with it. I used double sided tape on the secondary reciever instead of velcro.
EARL
I looked at the new Futaba Spectrum and that is the way to go. Only one small receiver, no problem with installation. Good for any plane.
I have the Horizon DX6 system in my parkflyers and like it, but the two receivers in the DX7 and the attendant installation problems turned me off.
Regards,
Regards,
TAIL TWISTER
Yes. Mussers, my local hobby store, has one. Mr. Musser told me that that Futaba is also coming out with a 2.4 Ghz module for the Futaba 9ZAP Wc2 transmitters of which I have two so I will wait for that.
I was surprised that Tower doesn't list them in their catalog yet, but assumed that Tower is waiting for a large delivery. They are predicting availability by Mid
April, $219.00 for just a transmitter and receiver. Use your own servos or buy a complete system with servos. Do a search on the Tower site for [FASST] and read about it.
Regards,
Regards,
I've held the system in my hand. My LHS has one. Have you NOT seen it in person then?
I know it offers the range, and a single box receiver, but it's not all that nice of a transmitter. It looks like the controller that comes with RealFlight.
And the antennas are a little different than they appear. They are two wires about 5 inches long. Only the last 1 inch is actual antenna. The rest is not to recieve RF. You still want the spacing, just no secondary box to deal with.
Surely it can't be that hard to hollow out the fus or cut a hatch in a balsa fus to house the two recievers right? Or am I missing the big picture here? One can then also use short stubs of nylon antenna tube exiting the fus in the right planes for the antennas? Ok maybe I should shut up till I get my first spektrum reciever one day.
My satellite receiver is mounted with velcro to the side of the canopy area. Simple as that...
I also think that Spektrum already offers such modules.
You could easily put a hatch just about anywhere in profiles. Cut your opening, frame around it to replace any structural member you may have cut through, glue in some recessed hold down blocks, cut your hatch from 1/16 ply and screw it in place. Easy.
TailTwiter did a Woody for us and used the Spektrum satellite receiver. He mounted it on the side of the canopy with Velcro so when he removed the wing panel the receiver could be detached. I thought it was pretty slick.
Yup, many of the big bird guys were slapping theirs on an inside fuselage former with velcro, so I just slapped mine along side the canopy area with velcro. I have this on three profiles now, and have added one step...
On one plane, I broke off one of the little antennas. My LHS was willing to save me the shipping and time in trade for my warranty, so they fixed it right up. The one change is that I now puyt a tiny piece of tape holding each of the two little antenna pieces down. I was told that Spektrum has had issue with vibration breaking the short and fairly stiff little antennas off.
The tape makes for an additional step when I remove thre wing on my Copperhead Woody, but I think it's worth the extra effort.
With the three planes combined, I'm likely about 80 or 90 flights, and I spend lots of time tumbling and snapping. I've never been able to "remove" a satellite receiver from the velcro in flight. Even before the tape was added.
Simple Simon works for me...
OH
Thanks!
Here's a pix of a recently purchased 7000 receiver.
You can see they have tried to address the antenna flex issue.
I think this one would survive well mounted to the V2 fuse side.
The one that came with my DX7 system has the more fragile antenna setup.
On that one I took a piece of inner Nyrod and RC56'd it to the back of both receivers.
I then slipped a piece of appropriate sized heat shrink over the Nyrod ends capturing the
antenna ends.
I would take a picture but that plane is hanging in the garage with the canopy on.
Too lazy this morning I guess...
JLK
antenna ends.
JLK
