REVO SPUR GEAR ?'S
REVO SPUR GEAR ?'S
well , my spur geat is shredded. Is there any difference if you go 36T , 38T , OR 40T?
and I guess I should go ahead w/ a steel one right.
thanx.
thanx.
NE
RE: REVO SPUR GEAR ?'S
i think you should stick with the plastic one because its made to be a sacrificial peace so you dont tear up your whole tranny and have a hugge messsss!
As far as the spur gears go, its the following: 36t=more top end speed
38= stock one (no performance change)
40= more torque
hope this helps
40= more torque
hope this helps
AZ
ORIGINAL: warhead666
thanx.
thanx.
Here is the the difference in spur gear sizes. The smaller tooth size you go in a spur gear the
more top speed/less torque is the result. On the other side of the coin the larger the spur gear
the less speed/more torque you have. It is just the opposite on clutch bells, more tooth count
the more speed/less torque, less tooth count less speed more torque. As far as steel spur gears
go stick with stock plastic composite gears. If you are running a steel spur gear make sure you
are running a hardened clutch bell because a steel spur gear will chew up a stock steel
clutch bell. The stock plastic spur gear gives you a small amount of protection for your drive train
because it has some give and shock load protection where as a steel spur has no give.
If you are not smelling nitro fumes and listening to the sweet song youe not LIVING !!
