what is the most important ????
QC, CANADA
hello! i start my hobbies in rc and i have a question for battery
what is most importan between '' mah'' and '' voltage(numbers of cell) ????
becose i have this choice ???
9.6v 8-cell 3800 mAh
8.4v 7-cell...but 4200 mAh
what is the best ????
thank you !
thank you !
My Feedback: (325)
It depends whether you're after power or run-time.
The capacity (mah) will determine runtime, and the voltage (cells) determine power. Maybe you can get a 8 cell 4200.
QC, CANADA
yes it is for traxxas stampede xl-5 the maximum of battery is 8-cell but i don't know if he have a limit for ''mAh'' ????
ORIGINAL: killer23
PA
ORIGINAL: killer23
There, you answered your own question.
Ok it goes.
voltage=how much power and speed (more voltage means more powerfull but the motor and esc gets a bit hotter)
mah=like mentioned before more mah means more runtime.
QC, CANADA
Titan 12-turn 550 modified motor
XL-5 electronic speed control
it is correct for 8 cell battery ?
sorry i begin in r/c
![EEK!](images/smilies/eek.gif)
ORIGINAL: killer23
Yeh a higher turn motor provides more torque (more for off-road) where as a lower torn motor gives you higher speeds but cuts back on torque.
Im pretty shure the ESC can handle either one of those batterys.
No problem.
If i where you i would screw the nimh battery, and get a Brushless system and a LiPo battery, now that would be unbelivibely fast!!!!!!
QC, CANADA
