EMS Heavy Duty DSC Switch-Double Pole??
NE
The EMS Heavy Duty DSC Switch has a nice price, but I can't find any info on whether it has double contacts or if it is just a single pole switch with a heavy duty contact.
I am looking for the best switch for the price. I suspect the standard switches I have installed in my fleet are not functioning properly during flight and want to replace them with an upgrade. Does anyone have any suggestions on this subject?
RE: EMS Heavy Duty DSC Switch-Double Pole??
The switches are DPDT and are soldered to a circuit board. The positive red lead uses the contacts on both sides of the switch while both the negative and signal leads are attached to the board so they pass thru.
IMO, it's a much better quality switch than you see in a standard switch.
