SD Models 35% Yak 54
I am building a 35% yak 107" wing span has anyone tried using just 1 JR8711 servo in wing? Would this work. It seems to be a strong aileron.
RE: SD Models 35% Yak 54
I am flying one of these now and I have on a couple of occasions plugged one of the servos in backwards, both times it has been an outboard servo. When I check the radio the ailerons are working but a little slow on one side because the outboard servo is just setting there. I have been amazed that there is almost no noticeable deflection in the aileron. I think one servo might work real well and the worst thing that would happen is your ailerons might be a little weak and you would have to add the second servo.
