Drive cable question
AZ
Anybody have the newer style WHH team pro enforcer cable?
The ends are a bit different and I want to make sure the correct end is slid into the boat hull.
Both square ends
One end is a smaller square
One end is an elongated square that comes to more of a point.
I would have called Warehouse hobbies but no tech support on weekends. :shrug:
Thanks!
Both square ends
Thanks!
AZ
RE: Drive cable question
Instructions say to install the square end in the SPD unit first so I assume the non pointed square end is what goes into the boat and the pointed end is what will be showing for the cartridge portion.
Looks and fits good.
I wont run it until tomorrow for good measure to see if I can find any additional info
