Lipo Charger- Hook it up to a car battery? What?!?!
AL
So I decided to get back into RC after close to a decade off. I purchased the new rct04.1 and a Hyperion HP-EOS0606i DC Charger and a lipo. After opening the box and seeing the inputs being 2 small pos/neg clips I thought something must be wrong. Then I read the directions and it states they need to be hooked up to a 12v constant power source such as a car battery. Have I purchased the wrong charger? Just about every lipo charger I have seen shows the clips for the input. Whatever happened to plugging into a plain old wall outlet? Is there any other option that a car battery? Man, I may be too old for all this technical stuff! thanks in advance,
Moose
Moose
AL
yeah, there is nowhere in this charger for an ac power supply. I guess the car battery is the best option, I just don't want to screw up anything on my car while it's charging.
1 Post
it should have a port to plug one in, This one is $10 and should work. [link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6256&Product_Name=12V_5A _Power_Supply]power supply[/link]
1 Post
No your not putting AC into it, The power supply converts the AC to 12VDC so you just have to find a way to hook it up to the charger, look for a dc input other then the clips if it does not have on you can just solder onto the clip wires or you can buy a little power bar for the clips to attach to.
AL
ah ok. No alternate dc inputs. So you're suggesting cutting off the clips and connecting those wires to the power supply you posted earlier? I didn't realized it converted the ac to dc. thanks
1 Post
Bingo, You could do that or you could use some plugs and make it so you can still swtich it back to clips etc. here is a vid shows you where to buy one and the hook up etc.
[youtube]http://www.youtube.com/watch?v=lJ4eB0hvnQQ[/youtube]
personally I use a old computer power supply
there are instructions if you search in the electric forum on how to do it
like syco says, there is an easy project you can do to convert an ATX power supply for lab use. If you have a general understanding of electronics and soldering it will be quite easy.
[link=http://web2.murraystate.edu/andy.batts/ps/powersupply.htm]http://web2.murraystate.edu/andy.batts/ps/powersupply.htm[/link]
AL
gel- I am a novice with electronics at best, and I think I am going to try the banana plug route with the charger I have now, thanks!
