Losi owners
Losi owners
This question is for the people who have used the Losi 2wd trucks. I have a Speed-NT, and the rear drive axle uses the slotted rim, pin through the axle. I want to convert to use something ike a 12mm, but what I need, is a solution for the front axles. Since it uses the bearings on the front, I can't find any adapters that I can use. Has anybody found a way around this problem? For reference, this is the same as the XXX-NT, and all the way back to the Junior-T/XX-T.
RE: Losi owners
ORIGINAL: proanti1
Why do you want to run 12mm hexes? I dont know of a company that makes them. The 17mm adapters are easily found for the slash though... and they would work on your losi.
